transmission
Old Dec 8, 2019 | 09:45 AM
Bruce vogel's Avatar
Default transmission
How many solenoids are in a transmission on a 1999 Ford Explorer
Old Dec 8, 2019 | 12:20 PM
It depends what trans is in the vehicle.
There must be a reason you are asking
can we ask what is the problem that has you suspecting the solenoids ?
Old Dec 9, 2019 | 07:23 AM
Default Transmission
I recently had an issue where I could start the vehicle but couldn’t throttle it up or put it in gear and throttle to go.Code retriever brought up about eleven codes for trans solenoid.fuel pressure is 60. It turned out to be a15 amp fuse and all is fine now
Old Dec 9, 2019 | 02:10 PM
Thank you for the update, glad you got id fixed. Have seen that problem with a fuse with diesels,but this is the first time with a gas engine.
Old Dec 9, 2019 | 02:43 PM
Default 4wheel drive
Hanky here’s one for you. When I start my 99 Ford Explorer the 4 wheel drive high and low flash for about six times. All work fine when physicaly engaged by using the dial selector
Deadman Walking
Sep 9, 2020 09:23 PM
Starkenburger
Sep 26, 2019 12:56 PM
mtnxhigh
News, Updates and Announcements
Jun 30, 2011 03:47 PM
tigerfan
Sep 25, 2008 11:45 AM
bpi
Apr 26, 2008 11:06 AM
