2004 Freestar rear lift gate handle
Old Dec 17, 2011 | 06:41 AM
  #281
minnesotamike's Avatar
Pop off the 1" x 1" access cover on the inside of the door. You can then try to work the latch to open the door. I have the schematics to fix the handle if you would like them. Just send me a PM, with your email address, and I can send them to you.
Mike
Old Jan 2, 2012 | 12:09 PM
  #282
Boomerang53's Avatar
Just a suggestion:
It appears to me that part of the cause of lift gate handle problems (apart from design flaws) might be pulling in too much of an upward direction on the handle, instead of more straight out which releases the latch with less strain on the handle parts.
Old Jan 5, 2012 | 11:12 PM
  #283
mwf's Avatar
mwf
Managed to reattach the handle (luckily it wasn't broken) on a 07 Freestar this weekend with help from a friend. After removing the small square plug on the inside of interior trim panel, we slid a large screwdriver in and after moving it back and forth we managed to unlock the rear hatch. We then were able to take off the interior trim pieces which allowed us to see the inside mechanism behind teh whte peice of glued on foam. We then slid the rod over with a large screwdriver from the inside which allowed us to slide the handle in from the outside and reattach the handle (quite a tight fit to get it in). I can now use the handle again to open and close hatch, but an inch black spring with straight ends fell out when we were trying to attach the handle. It does not seem to affect the opening and closing of the hatch but is there a diagram to show where it belongs and does anyone know what it serves? Thanks
Old Jan 6, 2012 | 07:08 AM
  #284
I have a couple diagrams for a 2004 Freestar that shows a spring. I don't think the Freestars changed much, so it should be similar. PM me with your email address if you want me to send them to you.
Mike
Old Jan 10, 2012 | 08:06 PM
  #285
shrektex's Avatar
Default So if i lost the handle...
How would i get another handle if i happened to lose it?
Old Jan 10, 2012 | 10:42 PM
  #286
I would suggest a salvage yard. You could also go new, but I'm sure they are rather expensive. And then they would possibly need to be painted to match your color.
Old Mar 8, 2012 | 12:01 PM
  #287
vmb72's Avatar
trying to open my 2004 freestar latch, handle came off in my hand....any info much appreciated!
Old Mar 9, 2012 | 06:29 AM
  #288
Send me your email address and I will send you the info. You can send that through a personal message from this forum or send it to minnesotamike at charter.net.
Old Mar 11, 2012 | 04:57 PM
  #289
adam baumel's Avatar
The rear latch to my 2004 ford Freestar will not lock. The handle is still intact. Would you please forward any information and diagrams that shows this mechanism.
Old Mar 12, 2012 | 08:06 AM
  #290
I can send the info, but I need an email address sent to the address above.
