View Poll Results: Can’t keep van running
Security Problem
0%
Coil Problem
0%
Fuel problem
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Van won’t stay running
Old Feb 16, 2021 | 07:06 PM
barrier1002's Avatar
Default Van won’t stay running
I have a 2004 Ford Freestar 4.2l. Out of no where my van just started randomly dying but would start right back up and run no problem at all and run fairly smooth. Then after about a week it died and wouldn’t stay running longer than 2 seconds tops then die.
All the codes I got was pretty much fuel related. I’ve checked the safety switch in back that turns off the fuel pump. Checked relay and fuse. Changed filter, pump, and fuel rail pressure sensor
When I changed the filter it was kinda clogged. Friend said he thought it was stuck in security mode. Guy told me to take my battery out and zip tie my two terminals together for 2 to 3 hours then put my battery fully charged back in cycle the key to the on position for 10 seconds then try to start it. Still after all these things same exact problem and if you give it any gas at all it immediately dies.
CODES:
Global OBD2 Ford: P0302, P0193, P0053, P2195, P2197, P0171, P0174, P0316, P0300
Ford continuous memory DTCs: P2006, P0193, P1000, P0053, P2197, P1100. Said there was 12 codes but 6 of them got deleted somehow off my photo album.
Old Feb 18, 2021 | 02:09 PM
You might be looking at a "Fuel Pump Driver Module" for your vehicle.
The symptoms are pretty much in line . Known to be troublesome.
Old Feb 21, 2021 | 08:44 AM
Default F
Thank you Hanky I will try that and get back with you.
droflex
Sep 22, 2016 04:14 AM
frankjr
Feb 26, 2014 11:02 AM
henro
Jan 26, 2013 05:12 PM
econobug
Aug 2, 2011 10:15 PM
russxlt
May 8, 2008 01:45 PM
