not sure what it is
Old May 4, 2008 | 11:14 AM
russxlt's Avatar
Default not sure what it is
my truck wont start for some reason. i have a 95 ranger 2.3L about 180,000 miles on it i drove home from work parked it then tried goin out and it wouldnt start it turns over and everything there arent any blown fuses its getting spark and it tries to start when i spray ether in it but it wont run. im thinking its the fuel filter but befrore i attempt to replace that i want to know if theres anything else it could be, hopefullt some small easy to get to switch that i have to turn on that doesnt include bloody knuckles haha
Old May 5, 2008 | 03:40 AM
Use Common Sense's Avatar
Default RE: not sure what it is
Could be a dirty fuel filter. However, even with a dirty fuel filter you normally will get enough fuel thru to start the engine. I would check for proper fuel pressure at the injector fuel rail. You could have a failed fuel pump or fuel pump relay. Do you hear the pump run for a few seconds when you turn the key on?
Old May 8, 2008 | 11:43 AM
cobra79's Avatar
Did it try and start with ether if it didn,t I would check compression, and if thats ok you need to check for an injector pulse. you can do that with a noid light
Old May 8, 2008 | 01:45 PM
techmanbd's Avatar
Also you can check the inertia switch that turns off the fuel when in an accident. I know you weren't in an accident, but it can go bad.
wendywoo92
Jan 2, 2008 12:19 PM
fmcobra1
Mar 15, 2007 03:40 PM
daveranger
Dec 10, 2006 03:44 PM
c_rob
Sep 30, 2006 11:21 PM
Nathan
Sep 24, 2006 05:32 PM
