Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Timing questions
Old May 21, 2019 | 08:23 PM
Skyler Jay Klontz's Avatar
Default Timing questions
I have an 07 freestyle that I put a new timing kit in and thought I had it but it appears that the timing is just barely off. I have the motor pulled again and want to strip It down to timing again. Remove the chains. And do a full reset. Is there any way to pull the chains off and figure out where is exactly correct timing again relative to the crank. Please let me know anything I can do
Old May 22, 2019 | 10:06 AM
Welcome to the site..
You can set the chain/ timing to sprockets with a marked link count to sprocket alignment marks..
12 links between I/E cams timing marks (R/L banks)
27 links between cam and crank marks (left bank/drivers)
30 links between cam and crank marks (right bank)
I can send you the illustration if needed...
Old Jun 6, 2019 | 03:33 PM
And I set all of that with the crank set at TDC cylinder one? Because I thought I had all of that correct but it seems when I put it back together it wanted to clatter.
Hearseman
Mar 2, 2017 02:36 PM
grumpy52
Jun 13, 2009 02:55 PM
glauten
Feb 21, 2008 08:41 PM
jim tierce
Nov 22, 2007 10:06 PM
sdpuff
Jul 9, 2007 12:58 PM
