2013 Fusion fuel filter
Old May 27, 2018 | 10:04 AM
panel's Avatar
Default 2013 Fusion fuel filter
Hello, the fuel filter for a 2013 Ford Fusion is a bit of a mystery for me, very little or nothing online , just wondering if you have changed yours or have seen location and instruction.My car has a 1.6 liter eco boost.
Thanks
Old May 27, 2018 | 12:00 PM
Maybe this post will be of some value and maybe not.
First if, you are planning to attempt to replace the fuel filter on your vehicle ,2013 Fusion, and you have never replaced a fuel injected vehicle fuel filter before , you might want to read up on the recommended procedure before getting a fuel bath and worse a possible fire. If this doesn't apply , skip it.
Sometimes if you aren't sure what the part looks like, purchase a new filter, now you see what you are looking for under the vehicle.
As earlier stated, changing a fuel filter that sets in a pressurized fuel line can present problems if you do not take certain precautions.
If you have done it before, just a reminder, if not, a WARNING , so please be careful.
Old May 27, 2018 | 03:35 PM
panel's Avatar
I've changed fuel filters on my truck but pulled the fuse first and turned over the engine to depressurize the fuel system.I did read you never have to change the fuel filter in this car but I've never heard of a filter that doesn't need changing.
Old Aug 14, 2021 | 10:33 AM
GunnyGee's Avatar
Did you learn anything about location of fuel filter on your 2013 Fusion? I have one and have the same question you had about it.
Old Aug 14, 2021 | 12:52 PM
panel's Avatar
No I never did find out.Must have one somewhere
Old Aug 14, 2021 | 01:07 PM
scott.butler4's Avatar
Vehicle does not have a serviceable fuel filter, there is a filter built into the fuel pump in the tank. I suppose you could replace the fuel pump if you really wanted to replace the fuel filter.
Old Aug 14, 2021 | 01:23 PM
panel's Avatar
Thanks Scott!,that answers that question.
EmmaJean500
Jul 10, 2015 04:18 PM
handyjohn
Feb 6, 2015 08:15 PM
Use Common Sense
Sep 12, 2008 11:20 PM
two slow
Mar 17, 2008 07:23 PM
kewiegand
Oct 27, 2007 07:17 PM
