A/c Wont Work
Old Jun 24, 2017 | 12:43 PM
11kiwis's Avatar
Default A/c Wont Work
Have a 2011 Fusion SEL AWD and the air con just stopped working out of the blue and dont even have the air blower option available either. After looking around I understand that it is a problem with the air con evap temp sensor. It needs replacing and it appears that it is an ongoing issue with these Fusions (not sure whether other Fords have this issue). The part cost around 25 bucks but just got off the phone with my local Ford dealership and they have quoted me 925 dollars to replace. The entire dash needs to come off and its the labor time that makes it so costly....I wonder if or when Ford will issue a recall on this issue? Heading into summer but I cant really afford 925 dollars on the car so unless other options are open to me (like putting down the windows) I will be without air con for the entire summer. Anyone has any thoughts, recommendations or address where I can write to Ford to complain about this widespread issue? Appreciate any feedback you can provide
Old Jun 25, 2017 | 05:09 PM
WyrTwister's Avatar
How did you determine the fault was the evap temp sensor ?
God bless
Wyr
Old Jun 26, 2017 | 03:40 PM
11kiwis's Avatar
God bless
Wyr
Just through may different people saying they have had exactly the same thing and everyone says it is the same thing. I suppose I should get the system tested but figured whats the point to spend money to find out what is most likely the problem. Just need to know how many complaints will it take for Ford to do something about this common problem in the Fusion and where I should complain to add my name to the list.
Old Jun 26, 2017 | 05:59 PM
It just could be something different and you might be jumping to a false conclusion. Why not have it checked out somewhere and confirm that is the actual problem, you could get lucky and not need to go the expensive route ?
kalabula
Sep 24, 2011 06:40 PM
Copier20790
Jul 28, 2011 08:41 PM
mtroofer
Dec 26, 2009 01:25 PM
marcn
Nov 22, 2006 08:19 PM
AndrewMacks4.0
Jul 13, 2006 12:44 PM
