Rear suspension leak and popping
Old Jun 5, 2023 | 08:14 PM
relative4's Avatar
Default Rear suspension leak and popping
Looking at a 2017 Fusion Sport with an enormous leak of sludgy greasy oily mess at the rear left suspension. For the life of me, I can NOT find the source of the leak. Not a CV boot, not the differential, not the wheel bearing, everything that turns is fine. And it's not coming from the shock. But it is all over the fuel & evap lines, and the suspension arms. It's just a huge mess down there.
When driving slowly, the car makes enormous popping noises like the axle is broken or something. And you can feel it as well as you can hear. As you go faster, it mostly smooths out.
Is this a known problem on these cars?
Old Jun 6, 2023 | 06:22 PM
Did you check the fluid level in the brake master cyl? It could be brake fluid leaking from the brake system in that wheel..
Swice
Sep 15, 2021 06:21 AM
dudeilf1219
May 4, 2013 11:34 AM
Focused_Mindframe
Dec 30, 2010 01:04 PM
glasshalffull
May 26, 2009 08:16 AM
ghopp420
Dec 21, 2007 02:44 PM
