Both windows will not roll up or down
Old Nov 2, 2015 | 03:34 PM
rdkurth's Avatar
Default Both windows will not roll up or down
I have checked the fuse and it is fine. I pulled the switch on the drivers door and check to see if power was coming to it and yes there is power to the switch . I was wondering does the passenger side door switch get its power from the driver side switch. I can not figure out what is wrong.
This is a 1991 Mustang Fastback
Old Nov 3, 2015 | 02:56 PM
The switch also has to have a good ground connection. If you want to , check if you are getting power to the passenger side switch and motor.
travis s
May 23, 2013 05:45 AM
Longhorns1
Jan 26, 2008 10:00 AM
kevinjohnson999
Oct 16, 2007 11:37 AM
Sabretooth
Oct 10, 2005 06:10 PM
