1990 2.9, starts but stalls right away
Old Nov 20, 2011 | 10:27 PM
kev966's Avatar
Default 1990 2.9, starts but stalls right away
Trying to help my nephew on his '90 ranger 2.9l. started dying on him at intermittent times. The fuel fiter and pump were replaced, now it starts but then dies right away, as if you turned the ignition off. I'm thinking maybe the TPS or possibly the ignition module. Any advice on what or what not to try ?
Old Nov 21, 2011 | 09:21 AM
kev966's Avatar
anything???? anyone????
Old Nov 21, 2011 | 03:04 PM
If you have a test lite to use, with the alligator clip connected to a good ground check any fuse that is energized when the key is turned on and see if you lose the connection from the ignition switch when released from the start position.
Hope I explained it clear enough . Let us know what you find.
Old Nov 22, 2011 | 01:03 AM
kev966's Avatar
will let you know... thanks
Old Nov 23, 2011 | 09:13 AM
kev966's Avatar
turns out to be the map sensor I beleive. I ended up replacing distributor, cause the cap hold down bolts snapped. Also the fuel rail, cause someone had twisted the inlet line to the point of cracking. So while I was at it, it got new plugs,cap, rotor, upper o-rings on injectors, fuel pressure regulator, air by-pass valve, and a TPS. None of this stuff helped, so just out of desperation, I started messing with vaccum lines and when I got to the MAP sensor, it changed everything. So I'm going to replace it and I do beleive it should work.
Commanderhayes
Jul 27, 2012 08:31 PM
elojs
Jun 18, 2012 05:34 PM
snapper1d
Dec 10, 2010 09:26 AM
streetglide007
Apr 11, 2010 12:23 PM
youngstah
May 28, 2008 10:01 PM
