1995 Ranger 45 cyl Opinion - Before I Buy It!
Old Sep 9, 2006 | 06:34 PM
apollo's Avatar
Default 1995 Ranger 45 cyl Opinion - Before I Buy It!
Hi all. My neighbor is selling his 1995 Ranger regular cab XLT, 5 speed, 4cyl, 2wd with 133K miles on it. He will sell it to me for $500. I am looking at this as a cheap 3rd vehicle that (I am assuming) gets good gas mileage. He has had it for 10 of the past 11 years (bought it a year old). While he did not take super care of it mechanically it's fairly clean. He told me that he has changed the oil every 3k to 4k. However, it idles and starts pretty rough. I will also eventually need a new windshield since the existing one has a crack in it. The check engine light is on too. Since he bought a new F150 a few months ago, he has barely driven the Ranger. So my questions are:
1. Is it worth it for $500?
2. Since I am not very mechanically inclined, are these trucks (specifically with the 4cyl.) expensive to fix?
3. Is 133K too much mileage to buy this?
Any advice and insight woudl be great!
Thanks!
Dave
Old Sep 9, 2006 | 08:33 PM
apollo's Avatar
Default RE: 1995 Ranger 4 cyl Opinion - Before I Buy It!
Whoops! I meant 4 cyl, not 45 cyl! Anyway, I just drove it. It drives fine. We went to Autozone to get the check engine code. The code is P1443 - Evaporative Emission COntrol System Control valve. Any ideas about that too?
Thanks!
Old Sep 9, 2006 | 11:39 PM
94 4x4 ranger's Avatar
Default RE: 1995 Ranger 45 cyl Opinion - Before I Buy It!
$500 is not bad i think it is worth it.[hr]It is not that expensive to fix vs the average car.[hr]For a truck with 133k it's still a good deal.
Old Sep 9, 2006 | 11:41 PM
DTC P1443 indicates an incorrect Evaporative System Purge Control Valve flow. This can be caused by a clogged, disconnected or broken vacuum line between the EVAP Canister Purge valve and the intake manifold as well as a bad EVAP Canister Purge valve itself..
Is the gas cap on correctly? If not this code may trigger this.
Old Sep 10, 2006 | 04:16 AM
apollo's Avatar
Gas cap is on correctly. Is this an easy fix? Thanks for your help!
Old Sep 14, 2006 | 05:49 AM
treetopp87's Avatar
1.yes its worth it
2.not expensive to fix thanx to autozone
3.that engine usually will run strong well over 300,000
my dad's has356,000 no engine work still runnin strong
so buy it man!
Old Sep 14, 2006 | 04:00 PM
apollo's Avatar
I will be picking it up tonight! I love this site. Thanks for the encouraging words!
Old Sep 14, 2006 | 06:08 PM
Great! and good luck with it.[hr]And if you ever need any help you know where to come.
Old Sep 22, 2006 | 03:31 PM
peacefulronin's Avatar
buy it or I will. Then I would have 2 rangers
Old Sep 23, 2006 | 12:54 AM
apollo's Avatar
Already bought it. In fact, I changed the following:
PCV
Fuel Filter
IAC Valve
Cleaned TB
I will be cleaning the MAF tomorrow. Already a night and day difference! Now, if I can only get the A/C Blower issue resolved .....
Dave
David53
Aug 2, 2013 07:56 PM
focusonitfletch
May 31, 2011 04:52 AM
SegunDunt
May 8, 2011 11:17 AM
BMER BOY
Feb 20, 2011 03:36 PM
mballentine
Apr 13, 2010 08:31 AM
