94 4.0 bogging under throttle
Old May 25, 2012 | 11:59 AM
JoeNoble's Avatar
Default 94 4.0 bogging under throttle
My 94 seems to idle fine but when I give it throttle it bogs really bad. It started out as an occasional issue and has gotten progressively worse. So I pulled the expensive NGK plugs and put in some cheap autolite plugs as that seems to be whats recommended and the NGKs were black.... REALLY black! Could it be the coil is bad or would it be more of a fuel issue?
Old May 25, 2012 | 02:25 PM
bluewind's Avatar
Yes.
If you have not done a proper tune up in a long time do it now. It seems to run rich.
replace or clean:
air filter
MAF sensor (clean with MAF sensor cleaner)
plugs, wires and coil pack
clean throttle body with throttle body cleaner
make sure the EGR system works properly.
Use techron fuel additive for a tank or two.
If you still have trouble after all that you may have leaking injectors.
Old May 25, 2012 | 02:36 PM
JoeNoble's Avatar
Thanks a ton for the response! I did a tune up (plugs, wires, air filter) cleaned the throttle body and the MAF sensor but it's gotten so bad now that I can't even drive it. I also put in a bottle of heat. Hadn't really thought about the egr, what should I look for?
Old May 25, 2012 | 02:37 PM
JoeNoble's Avatar
I brought the coil to work with me so I could test it. I was gonna bring the control module too but couldn't locate it on the truck.
Old May 25, 2012 | 07:35 PM
Here is a quickie you can check.
Locate the fuel pressure regulator on the fuel rail, remove the vacuum hose from the top and no gas should come out. If it is wet or has gasoline coming out that will result in a rich condition cause some black smoke and it can affect your fuel mileage.
Old May 26, 2012 | 09:45 AM
JoeNoble's Avatar
Well I just did a fuel pressure test and it had 30psi the book said it should have 30-45. I also checked the vac hose on the fpr and though it wasn't very snug it hadn't come off but there was some moisture in there. But once I was done with the test and put everything back she seems to run fine so somehow by checking the fuel pressure I fixed it?
Old May 26, 2012 | 12:52 PM
There should be no moisture or any kind of wettness in that line. Chances are the pressure regulator diaphram is leaking and may eventually come back to haunt you !
Keep a close eye on it.
WV-F150-4.2L
Mar 16, 2011 06:34 PM
melkaywig
Feb 21, 2008 10:31 AM
coater
Nov 21, 2005 02:26 AM
anthonyspeltz
Sep 20, 2005 04:15 PM
anthony
Sep 11, 2005 04:02 AM
