Clutch Issues Need help urgently
Old Jul 1, 2013 | 11:11 AM
Anthony Yogurtballs Irish's Avatar
Default Clutch Issues Need help urgently
I have a 1996 ford ranger. I have replaced the whole clutching system. There are no leaks and I very certin i have worked out all the air. The pedal feels great but here is my problem. I cannot shift it into gear while the truck is running and once i start it in first it will roll with the clutch engaged and will stall when i press the brake. The braket holding the master cylindar is fine and all other parts are new. SO what the hell is going on?
Old Jul 1, 2013 | 12:48 PM
bluewind's Avatar
How much free play do you have at the clutch pedal?
Old Jul 1, 2013 | 06:04 PM
Is it possible you have the clutch disc installed backwards?
It can go together either way , but will not work correctly if the disc is installed backwards.
makuloco2000
Jul 22, 2014 08:33 PM
jmelees
May 17, 2012 02:38 PM
cyberrkatz
Jul 7, 2010 09:46 PM
skid2964
Sep 27, 2009 02:29 PM
LoftisX4
Nov 9, 2005 09:54 PM
