Electrical problem
Old Nov 30, 2006 | 10:11 PM
gohuge192's Avatar
Default Electrical problem
Here's the problem. Got in my 1998 Ford Ranger 3.0 , turned the key to start it everything seemed normal. When I turned it all the way to start it nothing happened and I lost power to everything. No lights, door chime, nothing. After some time the power resumes to the accesories and I go to start it again and the same thing happens. I then take the battery to autozone to load test it and it turns out to be good. I put the battery back in my truck and it starts up. I drive to autozone and they test my alternator and battery again both good. Then drive home and now I have the same problem again, only now it takes about a day to get power back to the accesories. Any ideas, as i'm stumped.
Old Nov 30, 2006 | 11:44 PM
tylytle's Avatar
Default RE: Electrical problem
Bad ignition switch?
Old Dec 1, 2006 | 01:13 AM
wheelsup68's Avatar
Battery terminal connecitons?
Old Dec 1, 2006 | 01:41 AM
Check the connections on the Engine Compartment Fuse/Relay Box, as well as all the battery/ground cables and attachments.. The relay box is up in the left/drivers inner fender area, close to the firewall..
If a large amount of current draw 'breaks' the connection such as a start attempt, then after a short sit time or 'cooling' the connection can complete as long as no large demand for current is pulled through the bad connection..
Here's a pic of the relay box and it's connections as well as the location...
[IMG]local://upfiles/6756/68033DF8FF714764A8488B5C50286B84.gif[/IMG]
[IMG]local://upfiles/6756/FBDE726AA1054BE58F5F8D52AF587F14.gif[/IMG]
willijimon
Oct 21, 2018 08:07 PM
tigermonroe
Dec 21, 2005 11:06 AM
husky410
May 13, 2005 03:13 AM
husky410
May 11, 2005 06:51 PM
jgramke
Nov 22, 2004 07:40 PM
