Fuel hose/ tube
Old Aug 14, 2024 | 10:56 AM
2000 Ranger's Avatar
Default Fuel hose/ tube
Has anyone had to replace or repair a fuel line on a 2000 Ranger?
Old Aug 14, 2024 | 12:55 PM
A lot depends what that line carries.
If it is a return line, usually not much pressure, but if a supply line requires special type line to delivery point and also should be fuel and oil resistant..
Can you tell us where this line is?
Old Aug 14, 2024 | 07:22 PM
The line comes off the fuel pump with a 90 degree plastic fitting and then goes to the fuel filter. The clip is a white clip that you remove to get fuel line off. This is on a 2000 XLT Extended cab with a 3.0 V6 engine.
Last edited by 2000 Ranger; Aug 14, 2024 at 07:26 PM. Reason: Added more information
Old Aug 14, 2024 | 08:04 PM
There is a product called SYNFLEX. I believe that is what you may be looking for.
A good auto supply store should have all the components you would need to repair /replace a fuel line.
You must use the fittings made for that type line.
You might check on the net products made by EATON, or Weatherhead.
Welderguy
Aug 8, 2021 10:16 AM
VernonH
Sep 1, 2017 09:34 PM
danthedewman1
Jun 26, 2017 06:04 PM
Ford Fanatic
Feb 19, 2012 03:09 PM
dukesport
Nov 19, 2006 11:50 PM
