It might start, It might not? 94 4.0 2wd 5-spd
Old Mar 20, 2012 | 09:10 PM
Randy31163's Avatar
Default It might start, It might not? 94 4.0 2wd 5-spd
I noticed that if the "Check Engine Light" does not light up when key is turned on, it will NOT start, turns over but wont start. If light comes on, I know it will start. Could this be a relay or sensor going bad? And when it does start, it runs fine and no "Check Engine Light". Anyone got any ideas? Thanks
Old Mar 21, 2012 | 02:55 AM
A faulty EEC relay could cause this problem.
Old Mar 21, 2012 | 06:42 AM
Randy31163's Avatar
Default EEC tip
Thanks, I will go ahead and try that after work being it is inexpensive. The thing is, as I said, sometimes the light comes on and sometimes it don't so I guess I will only know that it corrected the prob if it never does if again. Or maybe I should wait until it fails to start again and change the EEC at that moment and see if it helps? After it sits a little while, it will eventually start back up. I'm all ears for any other suggestions. Thanks again with the EEC tip.
Old Mar 21, 2012 | 07:42 PM
Randy31163's Avatar
Smile So far so good Hanky, Thanks
I replaced the EEC relay and turned the key on and off many times with the CEL lighting up every time, so I started it and went for a ride. Stopped and turned key a few times again with good CEL results again. Started it and drove it some more and stopped it and started it a few more times with no more probs so far. Thanks a million Hanky!!! Before I changed the relay, I tried key and CEL lit up the first time. It failed the 2nd and 3rd time and that's when I changed it.
Old Mar 22, 2012 | 04:28 AM
You're welcome ! Another lucky shot!
Old Mar 22, 2012 | 06:46 AM
Randy31163's Avatar
I dunno about luck, I'd guess that you been around this a time or two. I appreciate it.
Old Mar 22, 2012 | 02:23 PM
If you read this forum a lot you will gain a lot of knowledge from many experienced folks here. That's how we all learn aside from the school of hard knocks. Thanks for answering if the suggestion was helpful or not. We always appreciate that.
focuslover
Dec 6, 2007 01:26 PM
valhallastar
Nov 14, 2007 11:21 PM
blue iron
May 1, 2007 09:59 PM
gonephishin
Jan 3, 2007 11:39 PM
nicholsmf
Oct 29, 2005 08:03 PM
