Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
2005 will not crank or start.
Old Jun 17, 2020 | 08:08 PM
Dave Nettles's Avatar
Default 2005 will not crank or start.
battery is good, dash lights up all lights and door locks work.
Old Jun 18, 2020 | 05:37 AM
Because not all vehicles, models or even years are the same , Need to know ;
Year
Model
Engine- if known
Do you have a second key, if so ,
try the other key. Could be a security system problem.
Old Jun 18, 2020 | 08:52 AM
Default 2005 sport trac
2005 sport trac 4.ol ,no crank no start
Old Jun 18, 2020 | 02:36 PM
What did you try?
Old Jul 7, 2020 | 02:42 PM
Default No crank no start
What did you try?
checked the keys, security system is good, pulled fuses, checked all grounds, new battery, new starter. Sometimes it will start for 3 days then nothing.
Old Jul 7, 2020 | 07:41 PM
Can we ask how you determined the security system was good ?
Old Jul 8, 2020 | 09:27 AM
I did a few recommended test. why would the truck sporadically start if the system was shut down. Any and all help here is appreciated, I've been on this thing for 2weeks.
Old Jul 8, 2020 | 11:51 AM
The functionality of your vehicle's security system is contained in the PCM. Starter is disabled when there is a problem.
What does the anti-theft light do when it will not start ?
Is it on then flashing or on solid for 60 seconds ?
When it would not crank over, you did try the other key , Yes/No ?
Old Jul 9, 2020 | 10:49 AM
P.o re rd wea ccx sQUOTE=hanky;119999]The functionality of your vehicle's security system is contained in the PCM. Starter is disabled when there is a problem.
When it would not crank over, you did try the other key , Yes/No ?[/QUOTE]
yes on the key. Solid for 3sec. then goes out. checked starter wire at ignition, shows power when trying to start.
Old Jul 9, 2020 | 12:49 PM
OK , from the start wire at the sw. it should go down to the sw on the side/top of the trans MLPS (Manual lever position sw) formally neutral safety sw. if automatic, if std shift , to clutch safety sw. from there to starter sol on starter.
tkp
Feb 6, 2020 03:37 PM
Kristófer Óskarsson
Apr 22, 2018 06:08 PM
philnn
Oct 2, 2011 10:40 AM
TIMLONEY
Aug 13, 2011 04:31 PM
rlindt
Dec 30, 2008 02:13 AM
