02 Taurus cranks but won't start
I am pretty sure the coils are fed Vref voltage (12 volts) from the PCM power relay, but need to confirm that from the diagram. If that is the case, with the key on, there should be 12 volts available at that white with the blue tracer wire at the coli plug. That is the next check I would suggest.
the crank sensor is generating 2.6 volts a/c not 1.5 .
don't know how critical that is. I am getting same voltage in the wire.
not sure exactly where to put test leads to check the coil. to copmound matters the coil is damn near impossible to get to without removing the plenum again.
i HAVE INSTALLED THE NEW CAM SENSOR AS WELL AND STILL HAVE NOTHING. i AM SO FRUSTRATED AND UPSET RIGHT NOW i DON'T KNOW WHAT TO DO. i AM OUT OF MONEY AND OUT OF TIME AND NEED TO RETURN TO WORK ON MONDAY WITH NO CAR. I NEED A MIRACLE RIGHT ABOUT NOW.
Thank you guys for any further help you can provide.
Any chance you are anywhere the Eastern Shore of Maryland?????
thank you, Bill
Can you please send a copy of the whole page with the wiring schematic? or point me to a place I can download it?
thank you
Bill
That voltage at the white/blu wire MUST have battery voltage. Either the battery is low or the wire is rubbing on something to cause the reading to be lower or there is just a poor connection preventing the coil from performing. I know the weather is not being cooperative, but in order to be sure and not just hope , the voltage reading at the coil has to be verified and checked right at the coil plug. Could one of the wire terminals have been pushed out when the plug was reinserted, it does happen !!
I'm going to ask another dumb question, where did you purchase the coil?
Did you check the ground connections ? If the PCM has a poor or no ground it can't control the coil. You might even try unplugging and reinstalling the plugs to the PCM.
Did you check the ground connections ? If the PCM has a poor or no ground it can't control the coil. You might even try unplugging and re-installing the plugs to the PCM.
DAMN is miss my older cars!!!!!! LOL
the safety neutral switch activates the starting sequence by allowing the current to energize the starter so from what I am getting that part is good and working properly. from what I'm getting from all these posts on this thread it's looking like the pcm just fried and the only way to know that for sure is by replacing it. and unless as Hanky said a wire is broken or not connected good and tight then that's the only other explanation
According to the diagram, it should be the white/blu tracer wire.The same wire you are checking and got the battery voltage. I know this is a lot of trouble , but we can't keep throwing parts at this thing because it gets expensive and is a lot of unnecessary work.
By the way where did you tap into that wire to check it ?
You have enough trouble right now and don't need any addl from me regarding parts from Autozone.
I hope schroensr can manage to send the rest of that diagram over for us.
