02 Taurus cranks but won't start
Old Jan 11, 2014 | 04:39 PM
  #51
schroensr's Avatar
Bill, my car is a floor shift. What is yours?
Old Jan 11, 2014 | 04:49 PM
  #52
schroensr's Avatar
Bill, push in on the crank position sensors pig tail just to see if there is a connection problem with the tire off the car. This is how I found my problem.
Old Jan 11, 2014 | 04:56 PM
  #53
Trying to get a look at a diagram for your vehicle , having a heck of a time.
One diagram shows the wire to the coil as whit/blu another shows it as red.
In any case there should be only one wire at the coil plug (when unplugged) that when the key is on, should measure battery volts. If you have that , half of the check is done. The other half is to leave the plug off the coil pack and any one of the other wires that come from the PCM to ground one of the coils should have no ground connection until the engine is cranked and the PCM grounds that coil to fire. Even if only one coil works the engine should attempt to start. If nothing happens there the PCM is suspect after the power and grounds have been verified.
Old Jan 11, 2014 | 05:16 PM
  #54
schroensr's Avatar
I am here if you need me. With the book open.
Old Jan 11, 2014 | 06:06 PM
  #55
I don't know if Bill is doing anymore today because he may be working outside and the temp is dropping and it's getting dark AND He probably has had it for today. He has a good one here and if we can help get it straightened out , he's going to be one happy camper.
Old Jan 11, 2014 | 06:53 PM
  #56
BillSinclair's Avatar
Angry
The biggest problem is the rain. I have a patio umbrella positioned over the hood are of the car, my neighbors probably think I'm crazy., but I have to get this thing fixed. I can't get to the plug for the coil without taking off the upper plenum again and that just ain't happening today.
I've pushed it in, pulled it off, pushed it in. I'm getting a signal in the wire so I dont think the plug is the problem
Mine is automatic
If it is the PCM then I am just out of luck. I am broke and my pay checks for the next month are spoken for. Not sure how I will ever get back on the road if it is the PCM.
Old Jan 11, 2014 | 08:28 PM
  #57
schroensr's Avatar
Where are you on the eastern shore? Mine is a auto on the floor, not on the steering wheel.
Old Jan 11, 2014 | 08:46 PM
  #58
schroensr's Avatar
Text me in the am , should be up around 8am .
Old Jan 12, 2014 | 05:38 AM
  #59
Until you actually verify that signal from the crank sensor is getting to the PCM we don't know where we stand. If that wire is open anyplace we are not sure it is OK. The only other way we might verify this is by checking at the coil for power and the signal from the PCM to fire the coils, (Provide the ground while cranking & running).
Old Jan 12, 2014 | 07:13 AM
  #60
schroensr's Avatar
I understand that sir. I'm here most of the day.
