97 Sable No Turn Signals
Old Nov 26, 2007 | 03:51 PM
  #11
Big merc's Avatar
Default RE: 97 Sable No Turn Signals
ORIGINAL: way2old
I would go ahead and try to get them to work without the 4 way flashers turned on. Try spraying down in the button area and see if it will help you. Other recourse is to buy the multi function switch. Click here for switch and approximate price. Replacement is really easy also. Let us know.
I'll have to wait till i get my check on the third of the month,
But i will try the sprays soon an let you know.
Thanks Much again.
MIKE
Old Nov 27, 2007 | 01:48 PM
  #12
Big merc's Avatar
ORIGINAL: way2old
OK, I went out an done a litter tinkering.
First i sprayed with the clearner, then the WD-40 pushed the button up & down serveral times, The 4 ways are working with the buttonUP Is that the on position, button UP?
if so pushing the button DOWN (OFF) The turn signals are working
I guess this is same as before for me with signals working with the button DOWN But no 4 ways working, I would say the cleaner & WD got my 4 ways working again.
4 ways OFF inDOWN Position? ON in UP Position?
Yes, i'm getting a bit confused with all this, I should of stuck with a GM [:-]
Old Nov 27, 2007 | 03:13 PM
  #13
Sounds like your good to go..
Button 'up' is 4 way/hazards lamps..
Button 'down' is turn functions....
Old Nov 27, 2007 | 04:45 PM
  #14
Big merc's Avatar
ORIGINAL: Hayapower
THANKS EVERYBODY for the time you took out of your busy days to help me with my problems.
Does this mean that my Multi Function Switch is on it's way OUT?
Old Nov 27, 2007 | 07:30 PM
  #15
way2old's Avatar
Not necessarily. It could be dirt or spilled liquid that has gotten down in there. Just keep a can of lubricant handy for the future.[sm=happy046.gif] Good luck
Old Dec 10, 2007 | 10:14 PM
  #16
hartley106's Avatar
I'm also having a similar problem. My drive belt broke and I turned the flashers on and they did not work initially. They did begin to start working hours after I parked the car. I then replaced the drive belt and the idler pulley. I got in the car and turned on the turn signal and itdid not work, however, the flashers did. I've replaced the fuse and the flasher unit. They still are not working.[:@] Can anyone help?
Thanks!
Old Dec 11, 2007 | 06:03 PM
  #17
way2old's Avatar
Have you tried the lubrication thing? If all the fuses are good and the 4 ways and the brake lights work, I would replace the multi fi=unction (turn signal)switch. It is easily replaced and not all that expensive. You really need to start your own thread for your problem. You can reference it to another post, but a new topic will usually recieve more attention. Good luck.
demonking75
Nov 17, 2008 09:58 PM
danny88
Oct 29, 2006 01:07 PM
pilotlars
Aug 20, 2006 09:00 PM
vintrider
Feb 24, 2006 09:00 PM
vintrider
Feb 18, 2006 11:34 AM
