Vacuum hose for a/c.....
Old Aug 27, 2018 | 04:13 AM
Elena Laurence's Avatar
Default Vacuum hose for a/c.....
So new ac clutch now appears we have a problem all heating and cooling is only coming thru defrosting vent...Help can't figure out the vacuum lines to get heating etc thru the vents
Old Aug 27, 2018 | 01:54 PM
Since you posted in the Taurus section, is it safe to assume you have a Taurus ?
If so, there is usually a small vacuum line that goes into the inside of the vehicle through the firewall under the hood on the passenger side. that vacuum line sometimes comes apart or just breaks due to heat. Most of the time it is easy to see a plastic line about 3/16 of an inch thick that may be broken. If usually comes off a tee or other kind of connection on the intake manifold.of the engine.I the line is broken and leaks vacuum , you can get a rubber splice from just about any auto supply store and reconnect the broken line. Let us know how you make out with this OK ? , thanks.
thewallace
May 13, 2018 07:13 AM
Dynamic21
Jan 3, 2018 03:59 AM
baconater357
Feb 9, 2017 03:11 PM
Howard57
Aug 30, 2013 04:57 AM
dgoodall
Jun 3, 2010 09:58 AM
