Stalling!! Cranks but wont start!!
Old Jun 16, 2016 | 08:29 PM
olivomatt96's Avatar
Default Stalling!! Cranks but wont start!!
I have a 95 TBird 3.8 v6. I have replaced my distributor, spark plugs and wires. Changed fuel pump & fuel filer still my car stalls mostly while moving then cranks but won't start.. sometimes I get lucky others times I get screwed. My main prob is I can't figure out if it could be my ign coil overheating or maybe my air filter getting clogged.. I just don't know also when I drive in the rain the stalling happens more often or stays stalled. Any help?
Old Jun 17, 2016 | 05:03 AM
When it quits running, you might try giving the air cleaner a shot of carb/choke cleaner and see if it starts. If so , could be a fuel problem, but that can be affected by an electrical problem to the pump in the tank. The other thing you can try is to have someone crank the engine when it quits running and you check if spark is getting to the dist or plugs. If no spark , then go after the ign syst. Good possibility if coil is original that could be the problem.
If the air filter was a problem it would be present all the time.
Old Mar 21, 2017 | 10:14 PM
gironha's Avatar
yep. hardest thing is that you can only diagnose when the problem happens and you are probably away from home at that time. So have to take tools with you in the car.
markmc60
Dec 5, 2016 12:19 PM
Krazy Kris
Aug 3, 2013 06:58 PM
iownslaves
Apr 1, 2008 06:03 PM
krobman
Nov 29, 2006 04:09 PM
HERE
Nov 25, 2005 12:52 PM
