06 5.4L 3V camshaft crankshaft correlation
Old May 7, 2017 | 04:10 PM
Gregjg's Avatar
Default 06 5.4L 3V camshaft crankshaft correlation
My chains went hay wire and jumps teeth after guides were destroyed. Replacing chains, phasers, the whole kit.
How do I know the cams are aligned right with the crankshaft before I put chains back on?
Old May 7, 2017 | 04:49 PM
Gregjg's Avatar
if the crankshaft rotated (unknown how many times) and the cam shaft did not, how can you line it back up the way it should be before installing chains?
Old May 11, 2017 | 01:25 PM
There are marks on the crank gear and the phaser gears that must be in the required position to correctly install the chains. The procedure may be found on the U tube videos, since it would be too lengthy to offer here.
wildchildde1
Mar 31, 2009 12:29 PM
77FordF250
Sep 26, 2005 03:29 PM
clr0813@yahoo.com
Sep 21, 2005 01:42 PM
moochy1
May 28, 2005 10:56 AM
