1992 Ford E350 Transmission problems
Old Aug 4, 2005 | 10:33 PM
ksummers's Avatar
Default 1992 Ford E350 Transmission problems
I drive a small wheelchair bus powered by a 7.3L diesel ford engine.
I have trouble with the transmission. When the yellow overdrive light is flashing, the transmission works well. When the light is not lit, I have to manually change the gears. Now, if I hit a large bump on the road, then the overdrive light will flash and the bus will function normally again.
Is it harmful for me to shift manually, especially when I am underload?.
Any help would be appreciated
Keith
Old Aug 5, 2005 | 12:12 PM
Ramrod48's Avatar
Default RE: 1992 Ford E350 Transmission problems
Iam not sure what you mean you have to shift manually , as shift into OD. or shift all the gears ? , if your under a load I hope your letting up off the throttle a bit first . you said you hit a bump an it goes to working , Sounds like a bad connection somewhere , The 92's were really bad about the Thin lil wires in the coloum breaking off at the connections. killing OD. not that hard of a repair , you get a new shift handle to make the repair , you might want to try a junk yard to save a few bucks. If I was travelling under 50 mph I would kick OD out anyway.
RonaldD
Jul 2, 2015 02:37 PM
ssand746
Aug 6, 2009 09:19 AM
aboss
May 1, 2008 09:04 PM
glimmertwins
Nov 1, 2007 09:48 PM
slingshot37091
Feb 20, 2007 09:21 PM
