2012 Escape Both front brakes sticking
Old Mar 29, 2022 | 10:05 AM
Rodger J.'s Avatar
Default 2012 Escape Both front brakes sticking
Can the ABS Pump cause both front brakes to stay engaged? When you press the brake pedal the brakes stay engaged and slowly release.
Old Mar 29, 2022 | 10:43 AM
What brake work, if any, has recently been done?
Old Mar 29, 2022 | 11:26 AM
raski's Avatar
How slowly do they release? Does the pedal return back promptly? If it is long enough to crack open a bleeder. If the caliper releases immediately after opening a bleeder, the problem exists upstream from the caliper. Look at brake hoses, master cylinder or ABS unit. If the caliper does not release, it is binding internally or the slides are rusted up. Hopefully, it hangs up long enough for you to diagnose easily..
Old May 31, 2022 | 08:35 AM
reed-01's Avatar
Is the front-end out of alignment, Sometimes the driver traction control kicks in and applies the brakes ,
stupid friend
Aug 16, 2020 06:37 PM
akadan
May 5, 2010 07:29 PM
02 maine escape
Aug 6, 2008 02:03 PM
moose@pioneertax.com
Oct 31, 2006 05:28 PM
oscar7777
Sep 8, 2006 12:22 AM
