94 f-150 problems
Old Mar 24, 2011 | 04:45 PM
hurstbrian38340's Avatar
Default 94 f-150 problems
i have a 94 f-150 not familier with fords, but bought truck it ran good when it would get warm it would take it longer to start, usually turn key off and then try again and would start , then one morning wouldnt start at all, wasnt fireing at coil, so that evening replaced coil, started ran fine all day, and the next day, then parked the next night woke up the morning after, wouldnt start, n0ot fireing at coil again, so when i come home at diner i unhooked coil for a few min hooked back up it started ran fine rest of day that night i went ahead replaced coil with m.s.d coil replaced ignition module and distributer cap and rotor button, truck ran good for about 4 days no problems, then parked it sun night, woke up mon morning and wont start not fireing at coil, it has hot to hot side but when i spin it over with test light hooked to hot wire and ground i get nothing. been told could be pickup coil in distributer, any sugestions.
Old Mar 24, 2011 | 05:55 PM
Sounds to me like you're on the right trail.
Old Mar 25, 2011 | 06:17 AM
david paul's Avatar
check all ground connections
Old Mar 25, 2011 | 06:19 AM
david paul's Avatar
also replace coil wire going to distributor they will break down just like the plug wires have ran into bad coil wire several times let us know
Old Mar 25, 2011 | 04:28 PM
ground connections good not fireing from coil checked it before coil wire
Old Mar 25, 2011 | 06:08 PM
Signal from dist goes to PCM then to TFI Module then to coil to fire it. Many times the connections at the TFI module need to be worked to make sure they are clean and tight. Let us know if you require any further assistance , will try to assist.
Also make sure connections inside dist are good.
Old Apr 3, 2011 | 04:51 PM
it was pickup coil causing my problems went ahead and put a reman distributer in and new plugs truck is running again thanks for the advice and tips
trysomekita
May 11, 2006 12:13 AM
bnokle
Dec 14, 2005 02:32 AM
jjduedall
Nov 29, 2005 02:08 AM
NicksMeanGT
Nov 1, 2005 08:46 PM
Frosty4422
Jun 22, 2005 04:29 AM
