bad running
Old Apr 1, 2006 | 02:28 PM
chippendale's Avatar
Default bad running
I have a 92 f150 with a 302. I was driving and all of a sudden it started dieing then run then try to die then run, over and over. My alternator indicator shows no charge, I made it home O.K. and changed the alternator. does the battery have to have a FULL charge?
because it still does it and the indicator still says it's not getting a charge even with a charger on it.
Old Apr 1, 2006 | 05:55 PM
CoyoteRoede's Avatar
Default RE: bad running
there are two things that i can think of that might be messed up
one is the battery.
second is the cables that are running from the alternator to the battery. that is the only thing i can think of. my boss had a old chevy that was doing the same thing and it ended up being the ground cable. i dont know if this helps but i tried good luck young grasshopper.
MrSauga
Sep 19, 2012 04:26 PM
rlpatte
Mar 31, 2012 08:45 PM
lugnut86
Aug 24, 2010 09:30 PM
ycgoat
Oct 29, 2008 06:49 PM
Mardav111
Feb 2, 2007 04:37 AM
