Can someone help me figure out what transmission this is please
Old Aug 4, 2018 | 03:57 PM
Revoracer3's Avatar
Default Can someone help me figure out what transmission this is please
Looking for an aod trans for my 76 f150
the guy selling it thinks it's an Aod but not sure
thank you
mike
Old Aug 5, 2018 | 02:15 PM
It would help if you could provide a pix of pan and other side of trans case.
It is an AOD !
Old Aug 5, 2018 | 06:00 PM
Revoracer3's Avatar
It is an AOD !
thank you. I was hoping it was. Woohoo!
Old Aug 5, 2018 | 07:19 PM
I just know you are going to remove the pan and clean it and replace the filter ,right?
You can't do any damage just carefully removing the pan ,cleaning the inside of the pan , change the filter.
That will give you some idea of the condition of the trans. Better to do it while it is out than when it is installed.
Old Aug 5, 2018 | 07:59 PM
Revoracer3's Avatar
I'm going to rebuild it before install.
Do a little beefing up
Old Aug 5, 2018 | 11:01 PM
You have the piston/seal lip protector set? They were easy to slice or and/or damage the seals on install without the kit.
Governors like to come loss too.,
skully_68
Jul 5, 2013 04:07 PM
sectlandscaping
Dec 4, 2011 09:02 AM
ljfen
Aug 15, 2011 05:08 PM
cjbock
Feb 6, 2011 02:47 AM
forde350
Sep 25, 2010 04:52 AM
