Manifold replacement
Old Sep 13, 2023 | 05:17 PM
koleszar902's Avatar
Default Manifold replacement
Just had my manifold replaced at a local exhaust shop, and just found out now they cut the frame to remove the old one and welded the piece back into the frame. Is this a proper way to do it? Without causing problems to my frame? Machanic told me he been doing it for 15 years that way and hasn’t had an issue with doing so. Just seems sketchy to me as everywhere else lifts the engine slightly to remove it not cut pieces of frame out to make room lol
Old Sep 13, 2023 | 08:15 PM
Welcome to the site.
What your Model/year?
Personally, I'd never cut on the frame to replace any part. Without a prior advisement as to the cut, I'd be pretty hot..
What size piece was removed?
Old Sep 14, 2023 | 05:27 AM
I completely agree with Hayapower.
Not to give you cause for worry, but I would keep a close eye on where the welds are because sometimes welds will crack adjacent to the weld and if it is at a stress point , , lets hope he was a good welder.
Old Sep 14, 2023 | 12:41 PM
it’s a 08 f150 5.4 and not sure another place told me a good size piece to remove the manifold
Old Sep 14, 2023 | 12:42 PM
yeah they are saying they done it like that for 15 years no issues but ford told me to bring it in they can inspect it and put brackets and a plate on it to prevent it from going out so I asked for a refund from other place
Old Sep 14, 2023 | 03:46 PM
You are in a tough place because they did the job, it works, and now we have to wait to see if they created a different problem..
I don't believe they are going to come up with any refund because they corrected the original problem. We just don't feel comfortable with the means they used.
Old Sep 16, 2023 | 10:31 AM
I got full refund for it and they are willing to either fix the weld and plate it or put a new shock tower in which is what they cut into not the main frame
Old Sep 16, 2023 | 02:31 PM
Great that you received a refund AND the offer to do the addl plating.. How did we come up with the frame being cut?
Old Sep 18, 2023 | 10:24 AM
they said they cut a section of the shock tower to get the manifold out, this is a reputable shop and they are certain it will not be an issue as this machanic does it like that so I’m not sure
adben22
Oct 25, 2015 09:42 AM
F250SUPERDUTYDUDE
Jan 15, 2012 05:38 PM
theboneskes
Feb 19, 2009 04:26 AM
timmar
Feb 23, 2008 07:27 PM
STEVE1103
May 17, 2005 09:55 AM
