overheating
Old Jul 15, 2007 | 04:00 AM
EL owner's Avatar
Default overheating
i have a 96 el falcon is overheating,stopped when i removed the thermostat but did it again when i put a bran new one in. any sugestions?
Old Jul 29, 2007 | 04:23 PM
dgordon's Avatar
Default RE: overheating
does your heater blow hot when at operating temp,you may have air trapped causing the over heat problem.
Old Jul 30, 2007 | 06:30 AM
Use Common Sense's Avatar
Have you ever had a cooling system flush and new coolant added? If not, the fins on the water pump could be worn off stopping the coolant from circulating.
askedofgod
Jul 18, 2015 11:53 AM
Hawk
Nov 15, 2013 08:05 PM
imjustanumber
Apr 18, 2005 12:36 PM
Cwzanth
Nov 25, 2004 06:10 AM
warren
Oct 22, 2004 05:19 PM
