Transfer Case plug issues 91 F250
Old Jul 21, 2019 | 03:47 PM
petreussg's Avatar
Default Transfer Case plug issues 91 F250
Hello all,
I've got two issues going on. I have a 91 F250 with what I think is the BW1356 transfer case.
Issue 1: My drain plug is soo stripped that the 3/8 drive just spins freely. I tried a bunch of stuff to get it off, which didn't work and made the stripping worse. What options do I have. Anything I can do without having to weld a socket or bolt to it? If that's my only option, I may need to take it to a shop for the needed equipment.
Issue 2: I need to replace both my fill and drain plugs on that transfer case. Does anyone know what size the plugs are? I can't find original equipment plugs online, but thought I could get some generic plugs if I had the size. I saw this: 1/2 MPT but don't really know what that means or if it's correct.
Thanks everyone!
Old Jul 21, 2019 | 07:51 PM
Since you went this far I presume you have the lube necessary to refill.
I believe what you read is 1/2 in. NPT = National pipe thread.
If you can any auto parts store should have that size plug. So would any hardware dept. If you want to tackle the job yourself , you could as you mentioned with welding a bolt on to the pug or you could drill a hole in the plug,use an easy out to remove the plug . You need to be careful because the case could be an aluminum alloy and might not take kindly to the heat although sometimes the heat will make it easier to remove, hard to tell.
If you feel you are not equipped to handle this , then best to have some one with the tools to do it.
Old Jul 22, 2019 | 05:57 PM
petreussg's Avatar
Thanks!
I'll try that size plug.
Unfortunately I think I'm going to have to take it somewhere to remove the drain plug. I'm not set-up for welding at home.
Sparky911
Apr 19, 2018 03:21 PM
Fredo181
Feb 4, 2017 01:03 PM
GasHog
Jan 17, 2017 07:25 PM
MatlockPaul
Jul 22, 2016 06:43 PM
SWOHSnow
Dec 11, 2009 11:03 AM
