2013 escape sel cranks no start
Old Dec 11, 2021 | 07:11 PM
carpet1's Avatar
Default 2013 escape sel cranks no start
the code crankshaft has low volt no spark battery full 1.6 eng code was p0337 over heated did not smell hot restarted then died
Old Dec 12, 2021 | 02:38 AM
scott.butler4's Avatar
Which engine, what all fault codes are present, what recent(last month) repairs, any visual damage, did engine have issues before this fault code set.
Old Dec 12, 2021 | 07:24 AM
carpet1's Avatar
1.6 Eng code was p0337 overheated did not smell hot went to limp mode cleard codes ran fine thendrove 10 miles shut off car started went a block now no spark hear fuel pump shut off thanks you
Old Dec 13, 2021 | 10:46 PM
So Ford doesnt list a P0337, google says its a crank sensor fault code. If there is a crank sensor fault the engine will stop running so that internal engine damage doesnt happen. Have you visually inspected the crankshaft sensor and wiring harness? How much did the engine overheat?
lindajordanfoss
Jan 25, 2022 01:06 PM
Hasgfd
Jun 29, 2021 07:13 PM
Stephv1
Aug 11, 2018 12:42 PM
NikjMiles
Jul 20, 2014 11:07 PM
bb97007
Aug 19, 2012 08:56 PM
