E350 Mysteriously Losing Oil.
Old Dec 14, 2019 | 09:59 AM
jquesada's Avatar
Default 2010 E350 Mysteriously Losing Oil.
In between oil changes every 3500 miles, my 2010 Club Wagon is losing about 3 qts of oil. There is NO visible oil leak, NO smoke and NO oil or soot in the tailpipe. Where is the oil going? 264,000 miles
Old Dec 14, 2019 | 01:18 PM
How does the coolant look and how is the coolant level?
Old Dec 14, 2019 | 04:14 PM
jquesada's Avatar
Actually, it looks a little brown and it's a bit oily to the touch.
Old Dec 14, 2019 | 04:15 PM
jquesada's Avatar
The level is a little low.
Old Dec 14, 2019 | 04:18 PM
jquesada's Avatar
It is mostly clear though, not milky and no oil spots that I could see. Also, I discovered today during my oil change that the used oil filter was too small. (I did not perform the last oil change and was not there to supervise)
Old Dec 14, 2019 | 09:07 PM
When you did your last oil change , how dd the bottom of the engine look?
Old Dec 15, 2019 | 07:22 AM
jquesada's Avatar
I did the oil change myself yesterday. The bottom of the engine looks fine. No visible oil or leak. I’m starting to suspect whomever did the last oil change only put 3 qts nstead of 6. They did put the wrong size filter after all.
Old Dec 15, 2019 | 07:37 AM
You could be 100% correct and sometimes the help is responsible, but at least now you know to keep an eye on the oil level.
Unfortunately, some places have problems getting good help and things like this do happen.
If you can, we would like to know if your theory was correct. Thanks.
Old Dec 15, 2019 | 01:40 PM
jquesada's Avatar
I’ll definitely keep an eye on it and let you know. Thanks for your time and input!
Kf4zub
Nov 11, 2018 11:18 AM
niallsdexta
Jan 14, 2013 04:17 AM
RocktheJungle
Oct 2, 2011 07:44 PM
luckyirishdb
Dec 25, 2007 11:13 AM
Kronos
Jun 21, 2005 07:18 PM
