please help 97 expedition trans
Old Sep 7, 2013 | 09:03 PM
reece84's Avatar
Default please help 97 expedition trans
I have a 97 eb expedition and when it shifts into od the od light will flash and tben it will shift hard I can turn the truck off an restart it turn off the od and it never does it
Old Sep 8, 2013 | 02:38 PM
diyautoelectric's Avatar
need to check codes , the OD light is flashing because there is a trouble code
Old Sep 8, 2013 | 10:26 PM
reece84's Avatar
Tryed that none is coming up
Old Sep 9, 2013 | 06:46 AM
Check where the shifter goes into the steering column, the wires from the overdrive switch break right there sometimes.
Old Sep 9, 2013 | 04:51 PM
Sometimes you need to play detective with these things.
It appears the PCM resets once you turn the key off, soooo, if you can after the problem surfaces again try to read the codes without shutting the key off and just maybe you might get a clue as to which system is causing the problem.
Old Sep 9, 2013 | 09:37 PM
reece84's Avatar
Il check the wires tomorrow but I've tried the scan without shutting it off and its just not workig for me fluid is good and red and full I'm ready to burn it lol
conanalois
Aug 31, 2013 06:16 AM
llazarus10
Mar 7, 2011 05:33 PM
davequest
Sep 12, 2006 04:16 AM
Seirpin
Oct 9, 2005 10:24 PM
