Slow engaging Transmission
Old Oct 28, 2011 | 02:03 PM
DIY Todd's Avatar
Unhappy Slow engaging Transmission
I have an issue with my econoline work van... When initially starting up, The transmission will go into reverse no problem but when engaged into drive it will take up to 3 minutes to slip into gear?? I've driven this van for 5 yrs, and owned it for one. It has always (in the last five years that i know of) done this. It will go directly into gear once it's warmed up and driven for a while, but once it cools down i start all over again... I have no other problems as it shifts great once it gets going down the road!! I'm a firm believer in not fixing it if it ain't broken and i've been waiting for it to drop on me but it seems that isn't going to happen... Can anyone identify with my problem and help me get off to a quicker start?
Thank you
Old Oct 28, 2011 | 05:20 PM
Sometimes I believe your reasoning could be correct, however, routine maintenance isn't quite the same as "it's broke". The idea is to try to keep it from breaking.
When was the last time the trans fluid and filter were changed ? That could be a good place to start in solving the slow engagement when cold problem.
There could also be a leaking clutch apply piston seal that when warmed up expands enough to allow a good seal. Let us know what you think and if the fluid and filter have ever been changed. Thanks
Old Oct 28, 2011 | 07:05 PM
DIY Todd's Avatar
Hanky,
Thanks for the input! This is my first post, sorry if it was so vague. I will definately do fluid and filter change to start with, as i have no idea when this was done last. or if at all... I so appreciate your response!!
Todd
Old Oct 28, 2011 | 07:08 PM
We would appreciate your reply as to what results you receive too. Thanks
rlrufus
Apr 26, 2015 11:51 AM
Paul McIntyre
Oct 16, 2012 03:54 PM
stewtheman
Jul 25, 2012 09:08 AM
fivewt
Apr 12, 2006 04:42 PM
alty79
Dec 10, 2005 06:38 PM
