2000 Windstar photos - new oil leak/stain on trans - normal??
Old Oct 27, 2018 | 11:11 AM
NYCDahon's Avatar
Default 2000 Windstar photos - new oil leak/stain on trans - normal??
Old Oct 27, 2018 | 06:37 PM
With time and age some parts on vehicles will show signs of seepage and if not considerable may not be cause for immediate concern.
Any leaks should be looked into and repaired.
Since you were able to make your way under the vehicle for the pix, could you check at the top of the engine to possibly see if the leak is coming from up top and running down to where you are noticing it?
Old Oct 28, 2018 | 03:26 AM
From past bad experiences , I don't use any "stuff" that gets added to any lubricant to make it stop leaking.You can try it if you want to.
There are products available at auto supply stores that will clean up and dry a leak area so it can be seen when & where the leak takes place then go from there.
Kf4zub
Nov 7, 2018 04:33 AM
MickJr
Oct 28, 2016 10:07 AM
Art5
Oct 19, 2013 07:08 PM
MY 93 F250
Jun 26, 2009 10:26 PM
fullbackmann25
May 23, 2009 06:24 AM
