98 Windstar starts easily then immediately stalls
Old 05-01-2018, 06:25 PM
BAB's Avatar
BAB
BAB is offline
Default 98 Windstar starts easily then immediately stalls
Windstar starts easily the immediately stalls, can hear clicking under dash just before stalls. Had same issue last year and found idle air control valve problem. If removed IAC valve it would run but very erratically. Replaced IAC valve and was great for several months, now same issue , but removing IAC valve does not make any difference. Can hear fuel pump run with key on. Checked fuses and for loose connections at MAF etc. Any ideas why the clicking under dash then shuts down? no sputtering, just shuts off completely.
Tried switching relays to see if PCM relay. fuel relays were bad, no luck
This is a 3.0
thanks
vmkrampitz
10-10-2021 10:45 PM
Revone11
05-22-2012 03:34 PM
morde1ac
12-05-2007 12:45 PM
jelmore
04-19-2007 02:05 AM
jinroh
04-01-2007 08:01 PM
Quick Reply: 98 Windstar starts easily then immediately stalls
