lights on warning chime
Old 01-16-2014, 06:38 PM
fullshaft's Avatar
Default lights on warning chime
Hey guys im new to this forum. I have a 1993 ford ranger, just the basic model with the 3.0. When I turn the lights on I hear a chime coming from the dash. Usually I wouldn't care but it does it nonstop even when im driving. It didnt start doing this until I washed out the engine bay a couple months ago. Is it possible I shorted something out? Any help would be great.
Old 01-20-2014, 11:46 AM
bluewind's Avatar
You could disconnect, inspect, dry and reconnect all the harnesses under the hood. But disconnect the battery before you get started.
There is also a computer connector on the firewall. I don't know it this one is only drive train related or if it also has body control functions.
Good luck!
Old 01-22-2014, 12:07 AM
fullshaft's Avatar
So some are covered in crud. Whats the best wsy to clean them?
Old 01-22-2014, 09:10 AM
bluewind's Avatar
Detach battery negative. Remove most crud with a rag. Use WD 40 or an electronics cleaner to blow off any water and oily stuff. When cleaning the connector pins you may use sand paper or a finger nail file. Put a little dielectric grease in the connectors before you reconnects them.
......but , honestly, I was tempted to tell you: " Ask your mom..."
Old 01-23-2014, 12:26 AM
fullshaft's Avatar
Haha guess I didnt word it too well... I will try that as soon as I get the dang thing running. Ive had nothing but problems with it since I got it!
Old 01-24-2014, 01:00 PM
bluewind's Avatar
Hey Fullshaft: I am glad you have some humor!
The more details you give us the easier it is to help out.
Old 01-25-2014, 10:09 PM
fullshaft's Avatar
Thanks again. No luck with cleaning the connections. I bought a Chiltons book, so now that I see it on paper I can just disconnect the dang thing.
JayKay
11-15-2011 08:09 AM
jerryman762005@yahoo
05-26-2008 01:31 PM
Daktari
12-02-2007 12:18 PM
delorean004
07-09-2007 03:48 AM
ranchhorse
03-24-2007 04:09 PM
Quick Reply: lights on warning chime
