'64 Fairlane PS valve issues
My '64 Fairlane (V8 260, 3 speed Cruisomatic) has a power steering pressure problem. When I take my hands off the wheel the car veers sharp right. I had to replace the pressure hose recently. Is there a pressure reducer adjustment on the valve. It's not an alignment issue, alignment correct and just done. Could this be a problem with the pump and not the valve? Friends are saying just take the PS out and retro to manual. Any thoughts and advice would be appreciated. Thanks! SJS
Some of the steering boxes back then had a spool valve on the top of the steering box. If one of the sealing rings on that spool valve is worn or leaking it would allow pressure to leak past and want to steer in the direction the fluid is traveling. Kits used to be available to repair that problem although most shops replaced the steering box.
Most of the time we try to utilize all of the features on a vehicle. If parts to correct a problem are difficult to obtain , we might do one thing, but if the parts can be obtained,there is nothing like using a vehicle as it was built to be driven.
There is a place called,
Vintage Parts Inc.
Beaver Dam, Wisc
They might have what you might need. Why not check it out before changing anything.?
Vintage Parts Inc.
Beaver Dam, Wisc
