Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Drum brake wheel cylinder question
Old Mar 15, 2021 | 02:11 PM
LADave's Avatar
Default Drum brake wheel cylinder question
1998 Contour SE with 8" rear drum brakes.
Should there be a spring between the wheel cylinder's little pistons? My rebuild kit didn't include one. Didn't find one inside the old cylinder, but the last guy who worked on the brakes was seriously lacking. Maybe just neglected to put it back in...
Old Mar 16, 2021 | 05:11 AM
Yes , definitely should have a spring in there.
It's purpose is to keep the brass expanders against the cups inside the wheel cyl.to maintain an effective seal.
Old Mar 16, 2021 | 10:36 AM
Some of the bargain wheel cylinder kits will only come with the piston cups, dust seals, and lube.
Old Mar 16, 2021 | 12:49 PM
LADave's Avatar
These pistons have seals set in recesses, so there's no way for seal and piston to get separated. So do I still need springs?
Old Mar 16, 2021 | 07:27 PM
This is the first time I have seen anything like this
.I'm not sure I would use them..
I have some reservations regarding travel of the cups and pistons.
Patrick Sheets
Aug 17, 2018 04:58 AM
joelrz
Jan 26, 2015 03:24 PM
blackharley
Aug 21, 2008 11:04 PM
1970 Galaxie
May 21, 2008 09:55 AM
jdog
Apr 30, 2005 09:28 AM
