wiring question
Old Oct 23, 2023 | 10:00 PM
stup71's Avatar
Default wiring question
Where is the easiest place to tap into my throttle and RPM signal? 2008 P-71.
Old Oct 24, 2023 | 05:02 AM
Can we ask why you are asking? Maybe we can save you from some problems.
Old Oct 26, 2023 | 07:30 PM
stup71's Avatar
I need throttle signal to talk to my NOS controller.
Old Oct 27, 2023 | 03:01 AM
Your vehicle has a CAN, Controller Area Network system and tampering with one of the inputs could cause problems.
What is a NOS controller ?
Does the place you purchased it from recommend it for your particular vehicle?
Many times items are for sale out there that are really not compatible with the new systems on some late year vehicles.
When first installed they seem to be OK, but a short time later strange problems develop and we assume it can't be the add-on because it worked before.
This is when it takes a tech a while to pin down the problem and disconnect the add-on to verify it is the thing causing the problems . Diagnostic time is getting more expensive every day.
You could always verify this with your local dealership service dept.
Old Oct 27, 2023 | 08:57 AM
stup71's Avatar
If someone has a wiring diagram for the TPS. I can probably figure it out. Thanks.
Old Nov 2, 2023 | 06:21 PM
You'll have an electronic throttle control. The Tach signal isn't available at the Accelerator Pedal Position Sensor, but possibly at the ETC module..
OldTimer67!
Mar 8, 2023 08:44 PM
rubles23
Jul 10, 2022 08:30 AM
Wymo88
Feb 5, 2022 10:45 AM
Tommy Knight
Dec 21, 2020 02:16 PM
shoebooty
Apr 26, 2008 11:29 PM
