1986 e350 tail lights
Old Feb 26, 2018 | 05:03 PM
SickDSM's Avatar
Default 1986 e350 tail lights
Former ambulance . Having trouble with rear left lights . Brake lights work, they shut off when either the headlights or turn signal comes on. All three work but not when another function is on . Right side works perfect. Is this a wiring issue or flasher malfunction? I'm confused how they work. Only two wires and the two separate filaments but therethe filament gets lit up every time.
Old Feb 26, 2018 | 05:13 PM
There should be 3 wires at the lower bulb socket.
One for tail lamps, one for stop.signal lamp and a ground wire. They did have problems with the ground wire rusting and braking away from the bulb socket.
jquesada
Aug 15, 2017 02:23 PM
crzyjef
Oct 5, 2016 04:17 AM
mbradywood
May 13, 2013 05:50 PM
lauraj
Sep 25, 2012 11:23 AM
MikeMurphyinKY
Jan 9, 2007 03:00 AM
