1989 Econoline 5.0L fuel issues and questions
Old Jul 18, 2021 | 11:36 AM
Welderguy's Avatar
Default 1989 Econoline 5.0L fuel issues and questions
My Ford econoline van with fuel injected 5.0L and 187000 miles. Has acceleration hesitation when engine is cold,not when engine is hot. and slight rough idol, and the issue of continuing to run reliably, issues. I have narrowed my focus to the fuel system.
I'm just the vehicle's owner and not a pro- mechanic, but I try and do as much repairs myself.
I would like to know, what should I look into being the problem s, because my fuel pressure is dropping off, when the engine is not running. Fuel pressure starts at 42psi. When I remove the vacuum line from the pressure regulator pressure climbs to 52psi. reconnect the vacuum line and pressure drops to 42psi. There is no fuel present or leaking from the vacuum line or the pressure regulator.
With the engine off, and fuel lines pressurized to 42psi, the pressure will drop to 35psi within 4 minutes, then to 25 psi after 6-8 minutes. Is this normal? or what could be causing this pressure drop? should I be concerned about the pressure drop shortly after the engine is turned off?
I replaced the MAP sensor, and that has helped the idol issue.
Thee is no Mass air flow sensor. Vehicle is located in NC, USA.
The fuel filter is 1 month old.
The high pressure fuel pump is new, having been installed just 2 weeks ago.
Engine starts right up when key is turned. very little engine cranking is needed.
Engine does has a slight amount of shake when idling, that can be felt through the valve covers, and heard at the engine's side. I'm thinking it is a miss or two. Could dirty fuel injectors cause that?
Could faulty or dirty fuel injectors cause the fuel pressure drop when engine is off?
Old Jul 18, 2021 | 01:44 PM
Usually if the fuel injectors are leaking, the pressure will drop, but that fuel has now gone into the cyls and could cause a hard start after soak time.
Good possibility fuel pressure regulator is leaking down. If you want to verify this, we just pinch off the fuel return line from the fuel regulator back to the tank. If the pressure holds now , the regulator is the problem.
Old Jul 19, 2021 | 11:16 PM
Welderguy's Avatar
That is a clever tip! thank you for sharing it with me!
n.shift
May 17, 2016 06:01 PM
saemetric
Jul 23, 2015 01:41 PM
raymo46
Apr 29, 2012 07:33 PM
pilleway
Jul 9, 2011 10:50 AM
digby
Mar 19, 2009 04:08 PM
