Blown motor
Old Nov 23, 2018 | 06:00 PM
Pnwmama's Avatar
Default Blown motor
I'm checking to see if my 6.8 V10 is blown, I pulled all the spark plugs and am wondering how hard should the compression be? Should it be easy to turn? Because it's really hard to get this one to turn, and when I go counter clockwise the bolt loosens. I noticed the new plugs I put in looked wet with a little rust on them. The starter is fine, battery is at full charge, help please , I don't know what I'm doing. Thanks in advance
Old Nov 24, 2018 | 08:55 AM
If the balancer bolt is coming loose, I’d say it’s bound up a bit.
With the plugs out and a decent bar/socket on its nose, it should rotate over fairly easy with a moderate pull. Have you taken an oil sample or cut the filter open? Sometimes a sample check wil reveal base engine debris and/or failures..
Any coolant loss etc?
Plugs out, starter won’t spin the engine over?
Old Nov 24, 2018 | 09:17 PM
Pnwmama's Avatar
yes, plugs are out and starter won't spin it over. When I bought the van he said it had overheated and wouldn't start, it got hot enough to crack the plastic radiator, so it has a new radiator and starter. I could've sworn it was turning over very slowly, I thought the batteries were bad. I put another battery in and then heard a high pitched squeal when I tried to start it. Now just a clicky noise at the starter. So I decided to go for it and pulled all the plugs to see if I could turn it.. it turns very hard and if I try to turn it counter clockwise the nut will come off. Could my starter motor be jammed on the flywheel and not letting it turn?
Also, I put brand new plugs and coils in when I bought it. When I pulled them out to check the compression the plugs were wet and looked a little rusty. They have never been started yet. I noticed that there was rain water dripping on to the motor from somewhere. Could rain water get into the plugs and rust it to where it's hard to turn? I live in Wa it rains all day long for months. I could've sworn it was turning slowly 8 months ago.
Old Nov 24, 2018 | 09:54 PM
Trying to turn it over, or the lack movement from the front balancer bolt may tell the story.
If it got crackling hot, better than average chance there's base engine issues. Have you taken an oil sample? Looking for coolant in the oil?
If the prior owner didn't have enough engine anti freeze/coolant, or not adequate meaning a high H20 concentration, and it sat for a long period rust in the bores could be a possibility.
Or, drag can be bottom end damage that would show up as suspended metals in the lube oil, and/or, contained within the oil filter if the damage occurred over some time..
Doubt the starter would jamb, but if your hearing it click/clunk, then its probably fine. Could remove it to be sure, but from what you've described the engine had rotation issue from the start. This was not a replacement starter, correct?
If your seeing rust on the electrode or the grounding wire, the moisture is generating within. If its on the outer hex of the plug, then possible external causes..
Old Nov 24, 2018 | 10:40 PM
Pnwmama's Avatar
Default Won't turn over
There wasn't any coolant , and it sat for 2 years the oil looked great but it had way too much oil in it about an inch or more pass the full mark. If the motor is blown I'm going to pull it, is it difficult ? Thanks for all your advice, I'm learning a lot
Old Nov 25, 2018 | 09:44 AM
Sounds like there was some coolant in the oil mix to raise the level.
When the plugs were out, did you use any lube injected in the cylinders prior to trying rotation?
So,, oil and filter was recently changed? If not, take an oil sample and cut the filter open for inspection, If the filter contains concentrations of metal debris,, it’s done.
Meaning, high concentrations of oil debris may indicate rotating assembly damage.
An inexpensive bore scope inserted into the cylinders may help with a diagnosis too. Cheap handhelds and smartphone driven units work pretty well.
If it looks like the engine is having issues, you could pull the heads first to get an idea of the damages done. Should the rest of the engine need to come out, it’s now lighter and easier to manage. On the install, as well as the removal you’ll need some basic equipment,, stands, jack and a good engine hoist as well as a good set of basic hand tools.
I can send you the engine removal steps/illustration for the task, and you can preview the work needed to remove the engine before you decide..
When the engine is subjected to excessive heat, cylinder scoring, galling of both the cyl bores and rotating items,, cams, bearings-rods and main bearings all can cause rotation drag or locking. As could corrosion.
Engine removal is a labor intensive job, but not terribly difficult if your equipped for the job.
If the idea is a used replacement engine for a swap, better yet.
But to garage build the existing engine, much more difficult.. If the current engine to be shop remanded, then just the basic replacement of all the engine dress components prior to the reinstall..
Generally a low/lowest mileage used if it can be sourced is fairly cost affective choice.. Making ‘sure’ of it’s run quality verifying it’s mileage, compressions, possibly run checked in the donor prior to removal, and from a good warranted source so the job doesn’t have to be repeated.....
Old Nov 25, 2018 | 04:41 PM
Pnwmama's Avatar
Wow, I can't thank you enough for all the information and support you have given me, it's invaluable to have someone with experience to turn to. Please send me anything you can about the engine replacement, yes I plan on using a new motor if I get to that point. You have givin me a lot to work on, I will let you know how it goes.
Old Nov 25, 2018 | 09:58 PM
Just so we’re all on the same page, what’s the model year?
Ill send the info to your email..
Old Nov 25, 2018 | 11:27 PM
Pnwmama's Avatar
03Ford strartrans bus with a v10 6.8 thanks I appreciate your time. I'm going to get started on it right away I found a 02 excursion with 70,000 on it for $2500 does that sound right ? I know nothing about engines but I'm willing thanks
killzone185
May 12, 2013 09:03 PM
benenuf
Mar 1, 2013 05:47 PM
dkaiser1963
Feb 23, 2008 09:08 PM
mwill0416
Jun 30, 2007 06:58 PM
degdawgs
Aug 19, 2005 07:32 PM
