No start no crank no nothin
Old Jun 16, 2023 | 12:30 PM
Mikeymike's Avatar
Default No start no crank no nothin
2011 E-150 sat for a couple of months . Installed new battery . Fired right up . Tried to move it all trans fluid had leaked out . Added trans fluid fired right up took it for a ride everything was fine . Went to move it . Nothing not a tick 1/2 crank nothing . Tried to jump it nothing . Have power dashboard lights up radio comes on windows work . Won’t crank
Old Jun 16, 2023 | 01:19 PM
Can you try this?
~Turn headlamps on and attempt to start the engine.
Watch what the headlamps do.
They may go out, go dim, or do nothing/
What they do can tell us what to check next..
Old Jun 16, 2023 | 02:07 PM
Mikeymike's Avatar
Turned on headlights tried to start they didn’t do anything
Old Jun 16, 2023 | 09:09 PM
The lights didn't change , so there is no problem with the battery or connections
There is a problem with the starter itself or the security system.. Do you have another working key to try? Sometimes a key will lose it's coding and a second working key , which we should always have, will answer that question. If the second key produces no change and the security lite goes out after you turn the key on, I would confine my efforts to the starter motor..Sometimes a TAP, not hard blow, to the starter will allow it to operate one or two more times. It is worth a try, let us know how you make out,thanks.
Pigpen
Dec 18, 2022 05:20 PM
Jgray19896
May 15, 2022 10:32 AM
Grantc1958
Mar 16, 2022 06:53 PM
fastonraceday
Aug 5, 2020 01:06 PM
FordNutz
Dec 14, 2007 11:37 AM
