Source Clock spring
Old Jul 2, 2022 | 08:21 AM
baribob09's Avatar
Default Source Clock spring
1992 Ford E350 Cutaway Class C RV.... Cruise stopped working and it appears the clock spring has failed. I need a replacement for the non-airbag but with cruise control. Any recommendations for a source. Have been unsuccessful on amazon or ebay. If you know of generic that I can install in the housing that would also work. This unit definitely uses the wrap around coil of flat wire tape.
gaballoon@windstream.net Thanks Baribob
Old Jul 2, 2022 | 02:03 PM
I would suggest you start with your local dealership parts dept. Some clock springs could be the same as newer vehicles and you just might get the right part the first time.
Old Sep 21, 2022 | 09:51 AM
divegirlfl's Avatar
Default Source Clock Spring
Baribob - if you'd only posted on one of the balloon sites a while back I just scrapped Dad's 1992 Ford Econoline recently. I'm now realizing I should have parted out a bunch of things before sending it away.
Gentle Breezes and Soft Landings,
Terry
For once you have tasted flight, you will forever walk the earth with your eyes turned skyward.For there you have been, and there you will always long to return.
Old Sep 30, 2022 | 12:24 PM
baribob09's Avatar
Thanks for the thoughts.... as time presses on these specialty parts become almost non existent. especially within any normal price range. I am also looking for the OEM parts number for the clock spring 1992 Ford E350 on a non-airbag, but with cruise control steering wheel. Would prefer new old stock but will take a used part in good condition.
Thanks
Robert
Old Sep 30, 2022 | 01:17 PM
You might try a few salvage yards. While there you may find other things you need and they are a lot cheaper than on line places.
If you ask , a Ford parts dept may be able to tell you what years they were the same.
Old Oct 4, 2022 | 06:28 PM
baribob09's Avatar
Found the OEM part number for the correct F2UZ13806B... 1992 FORD E350 TILT WHEEL CLOCK SPRING WITH CRUISE AND NO AIRBAG.
Fingaluna
Mar 23, 2018 01:29 PM
kevinlfifer
Sep 6, 2017 03:12 PM
ccookie66
Aug 28, 2012 01:42 PM
robert123
Jul 13, 2008 09:52 AM
david paul
Nov 29, 2007 11:14 AM
