V10 6.8l 2v head gasket removal
Old Feb 1, 2020 | 09:00 PM
Jeremy Good's Avatar
Default V10 6.8l 2v head gasket removal
I have a e-350 van with the 6.8l 2v engine. Everything is off the motor to the access of the camshaft and timing chain. Should I take off the rollers under the camshaft journals by decompressing the springs before removing the timing chain or can I lock timing chain down remove chain/guides then remove camshaft bolts 1/4 turn at a time then lash adjusters and rollers. Just curious which way to go about it so that nothing gets messed up with ttiming. Any information is greatly appreciated thanks
Panhead
Jan 2, 2020 03:03 PM
linconlsv8
May 3, 2015 09:00 AM
DaBossF250
Sep 28, 2014 05:53 PM
grumpy52
Jun 13, 2009 02:55 PM
jim tierce
Nov 22, 2007 10:06 PM
