When to add brake fluid on E150?
Old Jan 28, 2023 | 12:46 AM
rayluo's Avatar
Question When to add brake fluid on E150?
I know, that sounds like a stupid question. Most fluid reservoirs on most vehicles have their MIN and MAX line, so, the DIY maintenance is as straightforward as "when reaching or falling below MIN line, add fluid to MAX line". But the brake fluid reservoir of my 1999 Ford E150 van (and possibly all the model years from 1990 to 2007) has only a MAX line, but no MIN line. You can refer to the video of step 4 in this page, or the pictures of brand new part.
In the owner's manual, page 150, there is diagram showing MAX line but still no MIN line. And there is this line, "Do not let the reservoir for the master cylinder run dry. This may cause the brakes to fail.", which seemingly hints that the MIN line is the bottom of the reservoir. However, I am not sure whether the "reservoir for the master cylinder" means the brake fluid reservoir under the hood, or the piston inside the brake.
So, how do you know when to add brake fluid to your beloved Ford Econoline E Series Van?
Old Jan 28, 2023 | 05:03 AM
First,,,,,,,,,,,there could be 2 reasons for the brake fluid level in the master cyl to go down.
One is , if there is a leak in the system and the other is the brake pads are worn down where replacement is required.
Ford does not have any type warning when the pads require replacement and if found too late will require Pads and Rotors.
Paying attention to the level in the master cyl is a good way to keep an eye on things.
If you see the level is getting low, don't hesitate to add the DOT3 brake fluid. When the pads get replaced ,the piston in the caliper gets pressed back while the bleeder on the caliper is opened and the old contaminated fluid gets pushed out and the level must be checked again and refilled with fresh fluid.
Brake fluid should be replaced after 3-5 years because the brake lines develop problems from copper in the brake line that gets into the fluid.
Places that do brake work are usually aware of this.
Second,,,,,,,have the brake pads checked for wear.
Old Jan 28, 2023 | 11:32 AM
rayluo's Avatar
Thanks for the 2 things on WHY the brake fluid could get low. I'll certainly keep an eye on them.
But, as you also mentioned, "If you see the level is getting low", so, my question was, WHEN/HOW do I know the brake fluid level is considered low, while there is no MIN line on the reservoir?
Old Jan 28, 2023 | 02:38 PM
If it is below the level when you last filled it , find out why.
Either a leak or pad wear.
Old Jan 28, 2023 | 03:22 PM
rayluo's Avatar
I think I get it now. Let me rephrase my learning in a different way, so that you can double check whether we are on the same page.
1. First of all, unlike engine oil, the brake fluid will not be consumed by the vehicle. So, ideally, the brake fluid shall remain at the same level where it was last filled, and that line becomes the MIN line.
2. Therefore, when brake fluid drops below that "last fill line", we don't simply refill it to Max. We need to check for potential leak (which is abnormal and needs to be fixed), or pad wear (which is expected to gradually happen). After both checks and fixes, we then choose to either use the status-quo line as the new MIN line, or refill it to Max and use that Max line as the new MIN line.
With that logic, it sounds like the MIN line on my another vehicle's brake fluid reservoir is unnecessary. :-)
Thanks.
Old Jan 28, 2023 | 09:04 PM
What they are trying to tell us is , pay attention to the fluid level in the master cyl. Because if it is allowed to go all the way down it will allow air to get into the system. Which is not good. The reservoir is big enough that you will lose a piston popping out of a caliper or feel the metal to metal grinding well before it would pull any air in to the system..
Old Jan 30, 2023 | 10:32 PM
Rusty Baker's Avatar
I have never changed brake fluid in a vehicle in my 60 years of working on them.
Old Jan 31, 2023 | 07:18 AM
Hi Rusty,
That is the latest info we get. Check it out.
Glad to have you back.
purdum
Jun 8, 2021 09:52 PM
shelleya43
Aug 28, 2016 07:28 PM
Stonegod
Apr 1, 2013 09:48 AM
jeremyjudd
Dec 21, 2007 02:15 PM
78ford
Aug 11, 2005 12:02 PM
