“Transmission not in park”
Old Jan 1, 2021 | 08:42 AM
Jsasso's Avatar
Default “Transmission not in park”
Hello.
my 2016 escape has the “engine fault service now” light come on right after an oil change but before I could bring it it, as I pulled into my garage yesterday I suddenly got a “transmission not in park” red message. I was able to drive it into my garage and since have started it and gone back and forth in the driveway with no alert but I’m afraid to drive it and of course everything is closed for the holidays. Anyone have any experience with this or insight? Only like 30k miles on the car total.
thanks!
Old Jan 1, 2021 | 10:34 AM
If it is only the trans not in park, you could always use the paring brake to insure the vehicle won't move when you park it.
The other concern, fault service now is something you should not disregard. What you might do is check if there is any oil loss where the oil filter is mounted. Also check the engine oil level to insure no oil has been lost. Can we ask where the oil change was done?
Old Jan 1, 2021 | 11:14 AM
Jsasso's Avatar
thank you for your response! I’m definitely not disregarding! It was a perfect storm of moving, holidays etc that prevented me from taking it in immediately. My husband plans to bring it to our mechanic Monday morning. I had it changed at a drive up oil place that I’ve used before without issue.
I did try to get a code on the car even with the warning lit, nothing came up on the scanner, which is strange to me.
Old Jan 2, 2021 | 10:02 PM
Alexi Posadas's Avatar
Default I think it's the TR sensor it's a transistor in the gearbox I have the same issueso
Old May 11, 2022 | 09:46 AM
farelsavero's Avatar
Have you fix this problem? I have the same issue
swellclub2
Dec 26, 2015 02:35 PM
angie07
Jul 2, 2015 10:23 AM
mrhague
Nov 8, 2009 10:50 PM
pdougcool
Jul 23, 2009 05:39 AM
mets721
Aug 15, 2006 03:56 PM
