Ford Escape 2005 loses power after 2hours in traffic.
Old Feb 22, 2019 | 11:22 PM
  #11
SegunB's Avatar
Hello Hanky,
Thank you thus far for all of your assistance, I have had some work done and have attached the current diagnostics report. Does the O2sensor voltage readings look ok.
File Type: html
Old Feb 23, 2019 | 03:26 AM
  #12
Thanks for the info.
What work did you have done?
Some of the info is not relevant and some is incomplete.
We are missing the data at the time the engine is running.
From the codes listed the FPDM is suspect.
Also , it appears the PURGE valve may be stuck open flooding the engine with addl fuel and the sensors are attempting to correct that.
NOW ,,,,,,,,,,,,,, that will present an addl problem ,. Once the fuel problem is corrected the catalytic converter could have been damaged attempting to clean up the exhaust and that could come into the picture.
The FPDM appears a good place to start, and should be checked for physical condition .Then go from there.
There may also be a problem with the MAF sensor .
yarslew
Jan 16, 2020 01:56 PM
Greatwhite1983
Aug 6, 2012 10:47 PM
McStein
Nov 19, 2010 04:31 PM
ROADODG01
Dec 14, 2008 08:39 PM
kewiegand
Oct 27, 2007 07:17 PM
